<?php
* @package phpBB3
* @version $Id: viewtopic.php 9138 2008-11-30 16:53:36Z acydburn $
* @copyright (c) 2005 phpBB Group
* @license http://opensource.org/licenses/gpl-license.php GNU Public License
* @ignore
define('IN_PHPBB', true);
$phpbb_root_path = (defined('PHPBB_ROOT_PATH')) ? PHPBB_ROOT_PATH : './';
$phpEx = substr(strrchr(__FILE__, '.'), 1);
include($phpbb_root_path . 'common.' . $phpEx);
include($phpbb_root_path . 'includes/functions_display.' . $phpEx);
include($phpbb_root_path . 'includes/bbcode.' . $phpEx);
//ezermester includes:
require_once("root.inc.php");
require_once($GLOBALS['webroot']."/utils/adodb/adodb.inc.php");
require_once($GLOBALS['webroot']."/utils/adodb/adodb-exceptions.inc.php");
require_once($GLOBALS['webroot'].'/classes/forum/post.inc');
require_once($GLOBALS['webroot'].'/classes/forum/topic.inc');
//ezermester includes end
// Start session management
$user->session_begin();
$auth->acl($user->data);
// Initial var setup
$forum_id	= request_var('f', 0);
$topic_id	= request_var('t', 0);
$post_id	= request_var('p', 0);
$voted_id	= request_var('vote_id', array('' => 0));
$start		= request_var('start', 0);
$view		= request_var('view', '');
$default_sort_days	= (!empty($user->data['user_post_show_days'])) ? $user->data['user_post_show_days'] : 0;
$default_sort_key	= (!empty($user->data['user_post_sortby_type'])) ? $user->data['user_post_sortby_type'] : 't';
$default_sort_dir	= (!empty($user->data['user_post_sortby_dir'])) ? $user->data['user_post_sortby_dir'] : 'a';
$sort_days	= request_var('st', $default_sort_days);
$sort_key	= request_var('sk', $default_sort_key);
$sort_dir	= request_var('sd', $default_sort_dir);
$update		= request_var('update', false);
* @todo normalize?
$hilit_words	= request_var('hilit', '', true);
// Do we have a topic or post id?
if (!$topic_id && !$post_id)
	trigger_error('NO_TOPIC');
// Find topic id if user requested a newer or older topic
if ($view && !$post_id)
	if (!$forum_id)
		$sql = 'SELECT forum_id
			FROM ' . TOPICS_TABLE . "
			WHERE topic_id = $topic_id";
		$result = $db->sql_query($sql);
		$forum_id = (int) $db->sql_fetchfield('forum_id');
		$db->sql_freeresult($result);
		if (!$forum_id)
	if ($view == 'unread')
		// Get topic tracking info
		$topic_tracking_info = get_complete_topic_tracking($forum_id, $topic_id);
		$topic_last_read = (isset($topic_tracking_info[$topic_id])) ? $topic_tracking_info[$topic_id] : 0;
		$sql = 'SELECT post_id, topic_id, forum_id
			FROM ' . POSTS_TABLE . "
				" . (($auth->acl_get('m_approve', $forum_id)) ? '' : 'AND post_approved = 1') . "
				AND post_time > $topic_last_read
			ORDER BY post_time ASC";
		$result = $db->sql_query_limit($sql, 1);
		$row = $db->sql_fetchrow($result);
		if (!$row)
			$sql = 'SELECT topic_last_post_id as post_id, topic_id, forum_id
				FROM ' . TOPICS_TABLE . '
				WHERE topic_id = ' . $topic_id;
		if (!$row)
			// Setup user environment so we can process lang string
			$user->setup('viewtopic');
		$post_id = $row['post_id'];
		$topic_id = $row['topic_id'];
	else if ($view == 'next' || $view == 'previous')
		$sql_condition = ($view == 'next') ? '>' : '<';
		$sql_ordering = ($view == 'next') ? 'ASC' : 'DESC';
		$sql = 'SELECT forum_id, topic_last_post_time
		if (!$row)
			// OK, the topic doesn't exist. This error message is not helpful, but technically correct.
			trigger_error(($view == 'next') ? 'NO_NEWER_TOPICS' : 'NO_OLDER_TOPICS');
		else
			$sql = 'SELECT topic_id, forum_id
				WHERE forum_id = ' . $row['forum_id'] . "
					AND topic_moved_id = 0
					AND topic_last_post_time $sql_condition {$row['topic_last_post_time']}
					" . (($auth->acl_get('m_approve', $row['forum_id'])) ? '' : 'AND topic_approved = 1') . "
				ORDER BY topic_last_post_time $sql_ordering";
			if (!$row)
			else
				// Check for global announcement correctness?
				if (!$row['forum_id'] && !$forum_id)
				else if ($row['forum_id'])
					$forum_id = $row['forum_id'];
	if ((!isset($row) || !$row['forum_id']) && !$forum_id)
	else if (isset($row) && $row['forum_id'])
// This rather complex gaggle of code handles querying for topics but
// also allows for direct linking to a post (and the calculation of which
// page the post is on and the correct display of viewtopic)
$sql_array = array(
	'SELECT'	=> 't.*, f.*',
	'FROM'		=> array(FORUMS_TABLE => 'f'),
// The FROM-Order is quite important here, else t.* columns can not be correctly bound.
if ($post_id)
	$sql_array['FROM'][POSTS_TABLE] = 'p';
// Topics table need to be the last in the chain
$sql_array['FROM'][TOPICS_TABLE] = 't';
if ($user->data['is_registered'])
	$sql_array['SELECT'] .= ', tw.notify_status';
	$sql_array['LEFT_JOIN'] = array();
	$sql_array['LEFT_JOIN'][] = array(
		'FROM'	=> array(TOPICS_WATCH_TABLE => 'tw'),
		'ON'	=> 'tw.user_id = ' . $user->data['user_id'] . ' AND t.topic_id = tw.topic_id'
	if ($config['allow_bookmarks'])
		$sql_array['SELECT'] .= ', bm.topic_id as bookmarked';
			'FROM'	=> array(BOOKMARKS_TABLE => 'bm'),
			'ON'	=> 'bm.user_id = ' . $user->data['user_id'] . ' AND t.topic_id = bm.topic_id'
	if ($config['load_db_lastread'])
		$sql_array['SELECT'] .= ', tt.mark_time, ft.mark_time as forum_mark_time';
			'FROM'	=> array(TOPICS_TRACK_TABLE => 'tt'),
			'ON'	=> 'tt.user_id = ' . $user->data['user_id'] . ' AND t.topic_id = tt.topic_id'
			'FROM'	=> array(FORUMS_TRACK_TABLE => 'ft'),
			'ON'	=> 'ft.user_id = ' . $user->data['user_id'] . ' AND t.forum_id = ft.forum_id'
if (!$post_id)
	$sql_array['WHERE'] = "t.topic_id = $topic_id";
else
	$sql_array['WHERE'] = "p.post_id = $post_id AND t.topic_id = p.topic_id" . ((!$auth->acl_get('m_approve', $forum_id)) ? ' AND p.post_approved = 1' : '');
$sql_array['WHERE'] .= ' AND (f.forum_id = t.forum_id';
if (!$forum_id)
	// If it is a global announcement make sure to set the forum id to a postable forum
	$sql_array['WHERE'] .= ' OR (t.topic_type = ' . POST_GLOBAL . '
		AND f.forum_type = ' . FORUM_POST . ')';
else
	$sql_array['WHERE'] .= ' OR (t.topic_type = ' . POST_GLOBAL . "
		AND f.forum_id = $forum_id)";
$sql_array['WHERE'] .= ')';
// Join to forum table on topic forum_id unless topic forum_id is zero
// whereupon we join on the forum_id passed as a parameter ... this
// is done so navigation, forum name, etc. remain consistent with where
// user clicked to view a global topic
$sql = $db->sql_build_query('SELECT', $sql_array);
$topic_data = $db->sql_fetchrow($result);
if (!$topic_data)
	// If post_id was submitted, we try at least to display the topic as a last resort...
	if ($post_id && $forum_id && $topic_id)
		redirect(append_sid("{$phpbb_root_path}viewtopic.$phpEx", "f=$forum_id&amp;t=$topic_id"));
// This is for determining where we are (page)
if ($post_id)
	if ($post_id == $topic_data['topic_first_post_id'] || $post_id == $topic_data['topic_last_post_id'])
		$check_sort = ($post_id == $topic_data['topic_first_post_id']) ? 'd' : 'a';
		if ($sort_dir == $check_sort)
			$topic_data['prev_posts'] = ($auth->acl_get('m_approve', $forum_id)) ? $topic_data['topic_replies_real'] : $topic_data['topic_replies'];
		else
			$topic_data['prev_posts'] = 0;
	else
		$sql = 'SELECT COUNT(p1.post_id) AS prev_posts
			FROM ' . POSTS_TABLE . ' p1, ' . POSTS_TABLE . " p2
			WHERE p1.topic_id = {$topic_data['topic_id']}
				AND p2.post_id = {$post_id}
				" . ((!$auth->acl_get('m_approve', $forum_id)) ? 'AND p1.post_approved = 1' : '') . '
				AND ' . (($sort_dir == 'd') ? 'p1.post_time >= p2.post_time' : 'p1.post_time <= p2.post_time');
		$topic_data['prev_posts'] = $row['prev_posts'] - 1;
$forum_id = (int) $topic_data['forum_id'];
$topic_id = (int) $topic_data['topic_id'];
$topic_replies = ($auth->acl_get('m_approve', $forum_id)) ? $topic_data['topic_replies_real'] : $topic_data['topic_replies'];
// Check sticky/announcement time limit
if (($topic_data['topic_type'] == POST_STICKY || $topic_data['topic_type'] == POST_ANNOUNCE) && $topic_data['topic_time_limit'] && ($topic_data['topic_time'] + $topic_data['topic_time_limit']) < time())
	$sql = 'UPDATE ' . TOPICS_TABLE . '
		SET topic_type = ' . POST_NORMAL . ', topic_time_limit = 0
	$topic_data['topic_type'] = POST_NORMAL;
	$topic_data['topic_time_limit'] = 0;
// Setup look and feel
$user->setup('viewtopic', $topic_data['forum_style']);
if (!$topic_data['topic_approved'] && !$auth->acl_get('m_approve', $forum_id))
// Start auth check
if (!$auth->acl_get('f_read', $forum_id))
	if ($user->data['user_id'] != ANONYMOUS)
		trigger_error('SORRY_AUTH_READ');
	login_box('', $user->lang['LOGIN_VIEWFORUM']);
// Forum is passworded ... check whether access has been granted to this
// user this session, if not show login box
if ($topic_data['forum_password'])
	login_forum_box($topic_data);
// Redirect to login or to the correct post upon emailed notification links
if (isset($_GET['e']))
	$jump_to = request_var('e', 0);
	$redirect_url = append_sid("{$phpbb_root_path}viewtopic.$phpEx", "f=$forum_id&amp;t=$topic_id");
	if ($user->data['user_id'] == ANONYMOUS)
		login_box($redirect_url . "&amp;p=$post_id&amp;e=$jump_to", $user->lang['LOGIN_NOTIFY_TOPIC']);
	if ($jump_to > 0)
		// We direct the already logged in user to the correct post...
		redirect($redirect_url . ((!$post_id) ? "&amp;p=$jump_to" : "&amp;p=$post_id") . "#p$jump_to");
// What is start equal to?
if ($post_id)
	$start = floor(($topic_data['prev_posts']) / $config['posts_per_page']) * $config['posts_per_page'];
if (!isset($topic_tracking_info))
	$topic_tracking_info = array();
	if ($config['load_db_lastread'] && $user->data['is_registered'])
		$tmp_topic_data = array($topic_id => $topic_data);
		$topic_tracking_info = get_topic_tracking($forum_id, $topic_id, $tmp_topic_data, array($forum_id => $topic_data['forum_mark_time']));
		unset($tmp_topic_data);
	else if ($config['load_anon_lastread'] || $user->data['is_registered'])
// Post ordering options
$limit_days = array(0 => $user->lang['ALL_POSTS'], 1 => $user->lang['1_DAY'], 7 => $user->lang['7_DAYS'], 14 => $user->lang['2_WEEKS'], 30 => $user->lang['1_MONTH'], 90 => $user->lang['3_MONTHS'], 180 => $user->lang['6_MONTHS'], 365 => $user->lang['1_YEAR']);
$sort_by_text = array('a' => $user->lang['AUTHOR'], 't' => $user->lang['POST_TIME'], 's' => $user->lang['SUBJECT']);
$sort_by_sql = array('a' => 'u.username_clean', 't' => 'p.post_time', 's' => 'p.post_subject');
$s_limit_days = $s_sort_key = $s_sort_dir = $u_sort_param = '';
gen_sort_selects($limit_days, $sort_by_text, $sort_days, $sort_key, $sort_dir, $s_limit_days, $s_sort_key, $s_sort_dir, $u_sort_param, $default_sort_days, $default_sort_key, $default_sort_dir);
// Obtain correct post count and ordering SQL if user has
// requested anything different
if ($sort_days)
	$min_post_time = time() - ($sort_days * 86400);
	$sql = 'SELECT COUNT(post_id) AS num_posts
			AND post_time >= $min_post_time
		" . (($auth->acl_get('m_approve', $forum_id)) ? '' : 'AND post_approved = 1');
	$total_posts = (int) $db->sql_fetchfield('num_posts');
	$limit_posts_time = "AND p.post_time >= $min_post_time ";
	if (isset($_POST['sort']))
		$start = 0;
else
	$total_posts = $topic_replies + 1;
	$limit_posts_time = '';
// Was a highlight request part of the URI?
$highlight_match = $highlight = '';
if ($hilit_words)
	foreach (explode(' ', trim($hilit_words)) as $word)
		if (trim($word))
			$word = str_replace('\*', '\w+?', preg_quote($word, '#'));
			$word = preg_replace('#(^|\s)\\\\w\*\?(\s|$)#', '$1\w+?$2', $word);
			$highlight_match .= (($highlight_match != '') ? '|' : '') . $word;
	$highlight = urlencode($hilit_words);
// Make sure $start is set to the last page if it exceeds the amount
if ($start < 0 || $start >= $total_posts)
	$start = ($start < 0) ? 0 : floor(($total_posts - 1) / $config['posts_per_page']) * $config['posts_per_page'];
// General Viewtopic URL for return links
$viewtopic_url = append_sid("{$phpbb_root_path}viewtopic.$phpEx", "f=$forum_id&amp;t=$topic_id&amp;start=$start" . ((strlen($u_sort_param)) ? "&amp;$u_sort_param" : '') . (($highlight_match) ? "&amp;hilit=$highlight" : ''));
// Are we watching this topic?
$s_watching_topic = array(
	'link'			=> '',
	'title'			=> '',
	'is_watching'	=> false,
if (($config['email_enable'] || $config['jab_enable']) && $config['allow_topic_notify'] && $user->data['is_registered'])
	watch_topic_forum('topic', $s_watching_topic, $user->data['user_id'], $forum_id, $topic_id, $topic_data['notify_status'], $start);
	// Reset forum notification if forum notify is set
	if ($config['allow_forum_notify'] && $auth->acl_get('f_subscribe', $forum_id))
		$s_watching_forum = $s_watching_topic;
		watch_topic_forum('forum', $s_watching_forum, $user->data['user_id'], $forum_id, 0);
// Bookmarks
if ($config['allow_bookmarks'] && $user->data['is_registered'] && request_var('bookmark', 0))
	if (check_link_hash(request_var('hash', ''), "topic_$topic_id"))
		if (!$topic_data['bookmarked'])
			$sql = 'INSERT INTO ' . BOOKMARKS_TABLE . ' ' . $db->sql_build_array('INSERT', array(
				'user_id'	=> $user->data['user_id'],
				'topic_id'	=> $topic_id,
		else
			$sql = 'DELETE FROM ' . BOOKMARKS_TABLE . "
				WHERE user_id = {$user->data['user_id']}
					AND topic_id = $topic_id";
		$message = (($topic_data['bookmarked']) ? $user->lang['BOOKMARK_REMOVED'] : $user->lang['BOOKMARK_ADDED']) . '<br /><br />' . sprintf($user->lang['RETURN_TOPIC'], '<a href="' . $viewtopic_url . '">', '</a>');
	else
		$message = $user->lang['BOOKMARK_ERR'] . '<br /><br />' . sprintf($user->lang['RETURN_TOPIC'], '<a href="' . $viewtopic_url . '">', '</a>');
	meta_refresh(3, $viewtopic_url);
	trigger_error($message);
// Grab ranks
$ranks = $cache->obtain_ranks();
// Grab icons
$icons = $cache->obtain_icons();
// Grab extensions
$extensions = array();
if ($topic_data['topic_attachment'])
	$extensions = $cache->obtain_attach_extensions($forum_id);
// Forum rules listing
$s_forum_rules = '';
gen_forum_auth_level('topic', $forum_id, $topic_data['forum_status']);
// Quick mod tools
$allow_change_type = ($auth->acl_get('m_', $forum_id) || ($user->data['is_registered'] && $user->data['user_id'] == $topic_data['topic_poster'])) ? true : false;
$topic_mod = '';
$topic_mod .= ($auth->acl_get('m_lock', $forum_id) || ($auth->acl_get('f_user_lock', $forum_id) && $user->data['is_registered'] && $user->data['user_id'] == $topic_data['topic_poster'] && $topic_data['topic_status'] == ITEM_UNLOCKED)) ? (($topic_data['topic_status'] == ITEM_UNLOCKED) ? '<option value="lock">' . $user->lang['LOCK_TOPIC'] . '</option>' : '<option value="unlock">' . $user->lang['UNLOCK_TOPIC'] . '</option>') : '';
$topic_mod .= ($auth->acl_get('m_delete', $forum_id)) ? '<option value="delete_topic">' . $user->lang['DELETE_TOPIC'] . '</option>' : '';
$topic_mod .= ($auth->acl_get('m_move', $forum_id) && $topic_data['topic_status'] != ITEM_MOVED) ? '<option value="move">' . $user->lang['MOVE_TOPIC'] . '</option>' : '';
$topic_mod .= ($auth->acl_get('m_split', $forum_id)) ? '<option value="split">' . $user->lang['SPLIT_TOPIC'] . '</option>' : '';
$topic_mod .= ($auth->acl_get('m_merge', $forum_id)) ? '<option value="merge">' . $user->lang['MERGE_POSTS'] . '</option>' : '';
$topic_mod .= ($auth->acl_get('m_merge', $forum_id)) ? '<option value="merge_topic">' . $user->lang['MERGE_TOPIC'] . '</option>' : '';
$topic_mod .= ($auth->acl_get('m_move', $forum_id)) ? '<option value="fork">' . $user->lang['FORK_TOPIC'] . '</option>' : '';
$topic_mod .= ($allow_change_type && $auth->acl_gets('f_sticky', 'f_announce', $forum_id) && $topic_data['topic_type'] != POST_NORMAL) ? '<option value="make_normal">' . $user->lang['MAKE_NORMAL'] . '</option>' : '';
$topic_mod .= ($allow_change_type && $auth->acl_get('f_sticky', $forum_id) && $topic_data['topic_type'] != POST_STICKY) ? '<option value="make_sticky">' . $user->lang['MAKE_STICKY'] . '</option>' : '';
$topic_mod .= ($allow_change_type && $auth->acl_get('f_announce', $forum_id) && $topic_data['topic_type'] != POST_ANNOUNCE) ? '<option value="make_announce">' . $user->lang['MAKE_ANNOUNCE'] . '</option>' : '';
$topic_mod .= ($allow_change_type && $auth->acl_get('f_announce', $forum_id) && $topic_data['topic_type'] != POST_GLOBAL) ? '<option value="make_global">' . $user->lang['MAKE_GLOBAL'] . '</option>' : '';
$topic_mod .= ($auth->acl_get('m_', $forum_id)) ? '<option value="topic_logs">' . $user->lang['VIEW_TOPIC_LOGS'] . '</option>' : '';
// If we've got a hightlight set pass it on to pagination.
$pagination = generate_pagination(append_sid("{$phpbb_root_path}viewtopic.$phpEx", "f=$forum_id&amp;t=$topic_id" . ((strlen($u_sort_param)) ? "&amp;$u_sort_param" : '') . (($highlight_match) ? "&amp;hilit=$highlight" : '')), $total_posts, $config['posts_per_page'], $start);
// Navigation links
generate_forum_nav($topic_data);
// Forum Rules
generate_forum_rules($topic_data);
// Moderators
$forum_moderators = array();
get_moderators($forum_moderators, $forum_id);
// This is only used for print view so ...
$server_path = (!$view) ? $phpbb_root_path : generate_board_url() . '/';
// Replace naughty words in title
$topic_data['topic_title'] = censor_text($topic_data['topic_title']);
// Send vars to template
$template->assign_vars(array(
	'FORUM_ID' 		=> $forum_id,
	'FORUM_NAME' 	=> $topic_data['forum_name'],
	'FORUM_DESC'	=> generate_text_for_display($topic_data['forum_desc'], $topic_data['forum_desc_uid'], $topic_data['forum_desc_bitfield'], $topic_data['forum_desc_options']),
	'TOPIC_ID' 		=> $topic_id,
	'TOPIC_TITLE' 	=> $topic_data['topic_title'],
	'TOPIC_POSTER'	=> $topic_data['topic_poster'],
	'TOPIC_AUTHOR_FULL'		=> get_username_string('full', $topic_data['topic_poster'], $topic_data['topic_first_poster_name'], $topic_data['topic_first_poster_colour']),
	'TOPIC_AUTHOR_COLOUR'	=> get_username_string('colour', $topic_data['topic_poster'], $topic_data['topic_first_poster_name'], $topic_data['topic_first_poster_colour']),
	'TOPIC_AUTHOR'			=> get_username_string('username', $topic_data['topic_poster'], $topic_data['topic_first_poster_name'], $topic_data['topic_first_poster_colour']),
	'PAGINATION' 	=> $pagination,
	'PAGE_NUMBER' 	=> on_page($total_posts, $config['posts_per_page'], $start),
	'TOTAL_POSTS'	=> ($total_posts == 1) ? $user->lang['VIEW_TOPIC_POST'] : sprintf($user->lang['VIEW_TOPIC_POSTS'], $total_posts),
	'U_MCP' 		=> ($auth->acl_get('m_', $forum_id)) ? append_sid("{$phpbb_root_path}mcp.$phpEx", "i=main&amp;mode=topic_view&amp;f=$forum_id&amp;t=$topic_id&amp;start=$start" . ((strlen($u_sort_param)) ? "&amp;$u_sort_param" : ''), true, $user->session_id) : '',
	'MODERATORS'	=> (isset($forum_moderators[$forum_id]) && sizeof($forum_moderators[$forum_id])) ? implode(', ', $forum_moderators[$forum_id]) : '',
	'POST_IMG' 			=> ($topic_data['forum_status'] == ITEM_LOCKED) ? $user->img('button_topic_locked', 'FORUM_LOCKED') : $user->img('button_topic_new', 'POST_NEW_TOPIC'),
	'QUOTE_IMG' 		=> $user->img('icon_post_quote', 'REPLY_WITH_QUOTE'),
	'REPLY_IMG'			=> ($topic_data['forum_status'] == ITEM_LOCKED || $topic_data['topic_status'] == ITEM_LOCKED) ? $user->img('button_topic_locked', 'TOPIC_LOCKED') : $user->img('button_topic_reply', 'REPLY_TO_TOPIC'),
	'EDIT_IMG' 			=> $user->img('icon_post_edit', 'EDIT_POST'),
	'DELETE_IMG' 		=> $user->img('icon_post_delete', 'DELETE_POST'),
	'INFO_IMG' 			=> $user->img('icon_post_info', 'VIEW_INFO'),
	'PROFILE_IMG'		=> $user->img('icon_user_profile', 'READ_PROFILE'),
	'SEARCH_IMG' 		=> $user->img('icon_user_search', 'SEARCH_USER_POSTS'),
	'PM_IMG' 			=> $user->img('icon_contact_pm', 'SEND_PRIVATE_MESSAGE'),
	'EMAIL_IMG' 		=> $user->img('icon_contact_email', 'SEND_EMAIL'),
	'WWW_IMG' 			=> $user->img('icon_contact_www', 'VISIT_WEBSITE'),
	'ICQ_IMG' 			=> $user->img('icon_contact_icq', 'ICQ'),
	'AIM_IMG' 			=> $user->img('icon_contact_aim', 'AIM'),
	'MSN_IMG' 			=> $user->img('icon_contact_msnm', 'MSNM'),
	'YIM_IMG' 			=> $user->img('icon_contact_yahoo', 'YIM'),
	'JABBER_IMG'		=> $user->img('icon_contact_jabber', 'JABBER') ,
	'REPORT_IMG'		=> $user->img('icon_post_report', 'REPORT_POST'),
	'REPORTED_IMG'		=> $user->img('icon_topic_reported', 'POST_REPORTED'),
	'UNAPPROVED_IMG'	=> $user->img('icon_topic_unapproved', 'POST_UNAPPROVED'),
	'WARN_IMG'			=> $user->img('icon_user_warn', 'WARN_USER'),
	'S_IS_LOCKED'			=>($topic_data['topic_status'] == ITEM_UNLOCKED) ? false : true,
	'S_SELECT_SORT_DIR' 	=> $s_sort_dir,
	'S_SELECT_SORT_KEY' 	=> $s_sort_key,
	'S_SELECT_SORT_DAYS' 	=> $s_limit_days,
	'S_SINGLE_MODERATOR'	=> (!empty($forum_moderators[$forum_id]) && sizeof($forum_moderators[$forum_id]) > 1) ? false : true,
	'S_TOPIC_ACTION' 		=> append_sid("{$phpbb_root_path}viewtopic.$phpEx", "f=$forum_id&amp;t=$topic_id&amp;start=$start"),
	'S_TOPIC_MOD' 			=> ($topic_mod != '') ? '<select name="action" id="quick-mod-select">' . $topic_mod . '</select>' : '',
	'S_MOD_ACTION' 			=> append_sid("{$phpbb_root_path}mcp.$phpEx", "f=$forum_id&amp;t=$topic_id&amp;quickmod=1&amp;redirect=" . urlencode(str_replace('&amp;', '&', $viewtopic_url)), true, $user->session_id),
	'S_VIEWTOPIC'			=> true,
	'S_DISPLAY_SEARCHBOX'	=> ($auth->acl_get('u_search') && $auth->acl_get('f_search', $forum_id) && $config['load_search']) ? true : false,
	'S_SEARCHBOX_ACTION'	=> append_sid("{$phpbb_root_path}search.$phpEx", 't=' . $topic_id),
	'S_DISPLAY_POST_INFO'	=> ($topic_data['forum_type'] == FORUM_POST && ($auth->acl_get('f_post', $forum_id) || $user->data['user_id'] == ANONYMOUS)) ? true : false,
	'S_DISPLAY_REPLY_INFO'	=> ($topic_data['forum_type'] == FORUM_POST && ($auth->acl_get('f_reply', $forum_id) || $user->data['user_id'] == ANONYMOUS)) ? true : false,
	'U_TOPIC'				=> "{$server_path}viewtopic.$phpEx?f=$forum_id&amp;t=$topic_id",
	'U_FORUM'				=> $server_path,
	'U_VIEW_TOPIC' 			=> $viewtopic_url,
	'U_VIEW_FORUM' 			=> append_sid("{$phpbb_root_path}viewforum.$phpEx", 'f=' . $forum_id),
	'U_VIEW_OLDER_TOPIC'	=> append_sid("{$phpbb_root_path}viewtopic.$phpEx", "f=$forum_id&amp;t=$topic_id&amp;view=previous"),
	'U_VIEW_NEWER_TOPIC'	=> append_sid("{$phpbb_root_path}viewtopic.$phpEx", "f=$forum_id&amp;t=$topic_id&amp;view=next"),
	'U_PRINT_TOPIC'			=> ($auth->acl_get('f_print', $forum_id)) ? $viewtopic_url . '&amp;view=print' : '',
	'U_EMAIL_TOPIC'			=> ($auth->acl_get('f_email', $forum_id) && $config['email_enable']) ? append_sid("{$phpbb_root_path}memberlist.$phpEx", "mode=email&amp;t=$topic_id") : '',
	'U_WATCH_TOPIC' 		=> $s_watching_topic['link'],
	'L_WATCH_TOPIC' 		=> $s_watching_topic['title'],
	'S_WATCHING_TOPIC'		=> $s_watching_topic['is_watching'],
	'U_BOOKMARK_TOPIC'		=> ($user->data['is_registered'] && $config['allow_bookmarks']) ? $viewtopic_url . '&amp;bookmark=1&amp;hash=' . generate_link_hash("topic_$topic_id") : '',
	'L_BOOKMARK_TOPIC'		=> ($user->data['is_registered'] && $config['allow_bookmarks'] && $topic_data['bookmarked']) ? $user->lang['BOOKMARK_TOPIC_REMOVE'] : $user->lang['BOOKMARK_TOPIC'],
	'U_POST_NEW_TOPIC' 		=> ($auth->acl_get('f_post', $forum_id) || $user->data['user_id'] == ANONYMOUS) ? append_sid("{$phpbb_root_path}posting.$phpEx", "mode=post&amp;f=$forum_id") : '',
	'U_POST_REPLY_TOPIC' 	=> ($auth->acl_get('f_reply', $forum_id) || $user->data['user_id'] == ANONYMOUS) ? append_sid("{$phpbb_root_path}posting.$phpEx", "mode=reply&amp;f=$forum_id&amp;t=$topic_id") : '',
	'U_BUMP_TOPIC'			=> (bump_topic_allowed($forum_id, $topic_data['topic_bumped'], $topic_data['topic_last_post_time'], $topic_data['topic_poster'], $topic_data['topic_last_poster_id'])) ? append_sid("{$phpbb_root_path}posting.$phpEx", "mode=bump&amp;f=$forum_id&amp;t=$topic_id&amp;hash=" . generate_link_hash("topic_$topic_id")) : '')
// Does this topic contain a poll?
if (!empty($topic_data['poll_start']))
	$sql = 'SELECT o.*, p.bbcode_bitfield, p.bbcode_uid
		FROM ' . POLL_OPTIONS_TABLE . ' o, ' . POSTS_TABLE . " p
		WHERE o.topic_id = $topic_id
			AND p.post_id = {$topic_data['topic_first_post_id']}
			AND p.topic_id = o.topic_id
		ORDER BY o.poll_option_id";
	$poll_info = array();
	while ($row = $db->sql_fetchrow($result))
		$poll_info[] = $row;
	$cur_voted_id = array();
		$sql = 'SELECT poll_option_id
			FROM ' . POLL_VOTES_TABLE . '
			WHERE topic_id = ' . $topic_id . '
				AND vote_user_id = ' . $user->data['user_id'];
			$cur_voted_id[] = $row['poll_option_id'];
	else
		// Cookie based guest tracking ... I don't like this but hum ho
		// it's oft requested. This relies on "nice" users who don't feel
		// the need to delete cookies to mess with results.
		if (isset($_COOKIE[$config['cookie_name'] . '_poll_' . $topic_id]))
			$cur_voted_id = explode(',', $_COOKIE[$config['cookie_name'] . '_poll_' . $topic_id]);
			$cur_voted_id = array_map('intval', $cur_voted_id);
	$s_can_vote = (((!sizeof($cur_voted_id) && $auth->acl_get('f_vote', $forum_id)) ||
		($auth->acl_get('f_votechg', $forum_id) && $topic_data['poll_vote_change'])) &&
		(($topic_data['poll_length'] != 0 && $topic_data['poll_start'] + $topic_data['poll_length'] > time()) || $topic_data['poll_length'] == 0) &&
		$topic_data['topic_status'] != ITEM_LOCKED &&
		$topic_data['forum_status'] != ITEM_LOCKED) ? true : false;
	$s_display_results = (!$s_can_vote || ($s_can_vote && sizeof($cur_voted_id)) || $view == 'viewpoll') ? true : false;
	if ($update && $s_can_vote)
		if (!sizeof($voted_id) || sizeof($voted_id) > $topic_data['poll_max_options'] || in_array(VOTE_CONVERTED, $cur_voted_id))
			$redirect_url = append_sid("{$phpbb_root_path}viewtopic.$phpEx", "f=$forum_id&amp;t=$topic_id&amp;start=$start");
			meta_refresh(5, $redirect_url);
			if (!sizeof($voted_id))
				$message = 'NO_VOTE_OPTION';
			else if (sizeof($voted_id) > $topic_data['poll_max_options'])
				$message = 'TOO_MANY_VOTE_OPTIONS';
			else
				$message = 'VOTE_CONVERTED';
			$message = $user->lang[$message] . '<br /><br />' . sprintf($user->lang['RETURN_TOPIC'], '<a href="' . $redirect_url . '">', '</a>');
		foreach ($voted_id as $option)
			if (in_array($option, $cur_voted_id))
				continue;
			$sql = 'UPDATE ' . POLL_OPTIONS_TABLE . '
				SET poll_option_total = poll_option_total + 1
				WHERE poll_option_id = ' . (int) $option . '
					AND topic_id = ' . (int) $topic_id;
				$sql_ary = array(
					'topic_id'			=> (int) $topic_id,
					'poll_option_id'	=> (int) $option,
					'vote_user_id'		=> (int) $user->data['user_id'],
					'vote_user_ip'		=> (string) $user->ip,
				$sql = 'INSERT INTO ' . POLL_VOTES_TABLE . ' ' . $db->sql_build_array('INSERT', $sql_ary);
		foreach ($cur_voted_id as $option)
			if (!in_array($option, $voted_id))
					SET poll_option_total = poll_option_total - 1
					$sql = 'DELETE FROM ' . POLL_VOTES_TABLE . '
						WHERE topic_id = ' . (int) $topic_id . '
							AND poll_option_id = ' . (int) $option . '
							AND vote_user_id = ' . (int) $user->data['user_id'];
		if ($user->data['user_id'] == ANONYMOUS && !$user->data['is_bot'])
			$user->set_cookie('poll_' . $topic_id, implode(',', $voted_id), time() + 31536000);
			SET poll_last_vote = ' . time() . "
		//, topic_last_post_time = ' . time() . " -- for bumping topics with new votes, ignore for now
		trigger_error($user->lang['VOTE_SUBMITTED'] . '<br /><br />' . sprintf($user->lang['RETURN_TOPIC'], '<a href="' . $redirect_url . '">', '</a>'));
	$poll_total = 0;
	foreach ($poll_info as $poll_option)
		$poll_total += $poll_option['poll_option_total'];
	if ($poll_info[0]['bbcode_bitfield'])
		$poll_bbcode = new bbcode();
	else
		$poll_bbcode = false;
	for ($i = 0, $size = sizeof($poll_info); $i < $size; $i++)
		$poll_info[$i]['poll_option_text'] = censor_text($poll_info[$i]['poll_option_text']);
		if ($poll_bbcode !== false)
			$poll_bbcode->bbcode_second_pass($poll_info[$i]['poll_option_text'], $poll_info[$i]['bbcode_uid'], $poll_option['bbcode_bitfield']);
		$poll_info[$i]['poll_option_text'] = bbcode_nl2br($poll_info[$i]['poll_option_text']);
		$poll_info[$i]['poll_option_text'] = smiley_text($poll_info[$i]['poll_option_text']);
	$topic_data['poll_title'] = censor_text($topic_data['poll_title']);
		$poll_bbcode->bbcode_second_pass($topic_data['poll_title'], $poll_info[0]['bbcode_uid'], $poll_info[0]['bbcode_bitfield']);
	$topic_data['poll_title'] = bbcode_nl2br($topic_data['poll_title']);
	$topic_data['poll_title'] = smiley_text($topic_data['poll_title']);
	unset($poll_bbcode);
		$option_pct = ($poll_total > 0) ? $poll_option['poll_option_total'] / $poll_total : 0;
		$option_pct_txt = sprintf("%.1d%%", round($option_pct * 100));
		$template->assign_block_vars('poll_option', array(
			'POLL_OPTION_ID' 		=> $poll_option['poll_option_id'],
			'POLL_OPTION_CAPTION' 	=> $poll_option['poll_option_text'],
			'POLL_OPTION_RESULT' 	=> $poll_option['poll_option_total'],
			'POLL_OPTION_PERCENT' 	=> $option_pct_txt,
			'POLL_OPTION_PCT'		=> round($option_pct * 100),
			'POLL_OPTION_IMG' 		=> $user->img('poll_center', $option_pct_txt, round($option_pct * 250)),
			'POLL_OPTION_VOTED'		=> (in_array($poll_option['poll_option_id'], $cur_voted_id)) ? true : false)
	$poll_end = $topic_data['poll_length'] + $topic_data['poll_start'];
		'POLL_QUESTION'		=> $topic_data['poll_title'],
		'TOTAL_VOTES' 		=> $poll_total,
		'POLL_LEFT_CAP_IMG'	=> $user->img('poll_left'),
		'POLL_RIGHT_CAP_IMG'=> $user->img('poll_right'),
		'L_MAX_VOTES'		=> ($topic_data['poll_max_options'] == 1) ? $user->lang['MAX_OPTION_SELECT'] : sprintf($user->lang['MAX_OPTIONS_SELECT'], $topic_data['poll_max_options']),
		'L_POLL_LENGTH'		=> ($topic_data['poll_length']) ? sprintf($user->lang[($poll_end > time()) ? 'POLL_RUN_TILL' : 'POLL_ENDED_AT'], $user->format_date($poll_end)) : '',
		'S_HAS_POLL'		=> true,
		'S_CAN_VOTE'		=> $s_can_vote,
		'S_DISPLAY_RESULTS'	=> $s_display_results,
		'S_IS_MULTI_CHOICE'	=> ($topic_data['poll_max_options'] > 1) ? true : false,
		'S_POLL_ACTION'		=> $viewtopic_url,
		'U_VIEW_RESULTS'	=> $viewtopic_url . '&amp;view=viewpoll')
	unset($poll_end, $poll_info, $voted_id);
// If the user is trying to reach the second half of the topic, fetch it starting from the end
$store_reverse = false;
$sql_limit = $config['posts_per_page'];
if ($start > $total_posts / 2)
	$store_reverse = true;
	if ($start + $config['posts_per_page'] > $total_posts)
		$sql_limit = min($config['posts_per_page'], max(1, $total_posts - $start));
	// Select the sort order
	$sql_sort_order = $sort_by_sql[$sort_key] . ' ' . (($sort_dir == 'd') ? 'ASC' : 'DESC');
	$sql_start = max(0, $total_posts - $sql_limit - $start);
else
	$sql_sort_order = $sort_by_sql[$sort_key] . ' ' . (($sort_dir == 'd') ? 'DESC' : 'ASC');
	$sql_start = $start;
// Container for user details, only process once
$post_list = $user_cache = $id_cache = $attachments = $attach_list = $rowset = $update_count = $post_edit_list = array();
$has_attachments = $display_notice = false;
$bbcode_bitfield = '';
$i = $i_total = 0;
// Go ahead and pull all data for this topic
$sql = 'SELECT p.post_id
	FROM ' . POSTS_TABLE . ' p' . (($sort_by_sql[$sort_key][0] == 'u') ? ', ' . USERS_TABLE . ' u': '') . "
	WHERE p.topic_id = $topic_id
		" . ((!$auth->acl_get('m_approve', $forum_id)) ? 'AND p.post_approved = 1' : '') . "
		" . (($sort_by_sql[$sort_key][0] == 'u') ? 'AND u.user_id = p.poster_id': '') . "
		$limit_posts_time
	ORDER BY $sql_sort_order";
$result = $db->sql_query_limit($sql, $sql_limit, $sql_start);
$i = ($store_reverse) ? $sql_limit - 1 : 0;
	$post_list[$i] = $row['post_id'];
	($store_reverse) ? $i-- : $i++;
if (!sizeof($post_list))
	if ($sort_days)
		trigger_error('NO_POSTS_TIME_FRAME');
	else
// Holding maximum post time for marking topic read
// We need to grab it because we do reverse ordering sometimes
$max_post_time = 0;
//to be edited Perenyi Marcell:
$sql = $db->sql_build_query('SELECT', array(
	'SELECT'	=> 'u.*, z.friend, z.foe, p.*, pr.score',
	'FROM'		=> array(
		USERS_TABLE		=> 'u',
		POSTS_TABLE		=> 'p',
	'LEFT_JOIN'	=> array(
		array(
			'FROM'	=> array(ZEBRA_TABLE => 'z'),
			'ON'	=> 'z.user_id = ' . $user->data['user_id'] . ' AND z.zebra_id = p.poster_id'
                array(
			'FROM'	=> array('post_rating' => 'pr'),
			'ON'	=> 'pr.user_id = ' . $user->data['user_id'] . ' AND pr.post_id = p.post_id'
	'WHERE'		=> $db->sql_in_set('p.post_id', $post_list) . '
$now = getdate(time() + $user->timezone + $user->dst - date('Z'));
// Posts are stored in the $rowset array while $attach_list, $user_cache
// and the global bbcode_bitfield are built
	// Set max_post_time
	if ($row['post_time'] > $max_post_time)
		$max_post_time = $row['post_time'];
	$poster_id = $row['poster_id'];
	// Does post have an attachment? If so, add it to the list
	if ($row['post_attachment'] && $config['allow_attachments'])
		$attach_list[] = $row['post_id'];
		if ($row['post_approved'])
			$has_attachments = true;
	$rowset[$row['post_id']] = array(
		'hide_post'			=> ($row['foe'] && ($view != 'show' || $post_id != $row['post_id'])) ? true : false,
		'post_id'			=> $row['post_id'],
		'post_time'			=> $row['post_time'],
		'user_id'			=> $row['user_id'],
		'username'			=> $row['username'],
		'user_colour'		=> $row['user_colour'],
		'topic_id'			=> $row['topic_id'],
		'forum_id'			=> $row['forum_id'],
		'post_subject'		=> $row['post_subject'],
		'post_edit_count'	=> $row['post_edit_count'],
		'post_edit_time'	=> $row['post_edit_time'],
		'post_edit_reason'	=> $row['post_edit_reason'],
		'post_edit_user'	=> $row['post_edit_user'],
		'post_edit_locked'	=> $row['post_edit_locked'],
		// Make sure the icon actually exists
		'icon_id'			=> (isset($icons[$row['icon_id']]['img'], $icons[$row['icon_id']]['height'], $icons[$row['icon_id']]['width'])) ? $row['icon_id'] : 0,
		'post_attachment'	=> $row['post_attachment'],
		'post_approved'		=> $row['post_approved'],
		'post_reported'		=> $row['post_reported'],
		'post_username'		=> $row['post_username'],
		'post_text'			=> $row['post_text'],
		'bbcode_uid'		=> $row['bbcode_uid'],
		'bbcode_bitfield'	=> $row['bbcode_bitfield'],
		'enable_smilies'	=> $row['enable_smilies'],
		'enable_sig'		=> $row['enable_sig'],
		'friend'			=> $row['friend'],
		'foe'				=> $row['foe'],
                'user_has_rated'		=> $row['score'],
	// Define the global bbcode bitfield, will be used to load bbcodes
	$bbcode_bitfield = $bbcode_bitfield | base64_decode($row['bbcode_bitfield']);
	// Is a signature attached? Are we going to display it?
	if ($row['enable_sig'] && $config['allow_sig'] && $user->optionget('viewsigs'))
		$bbcode_bitfield = $bbcode_bitfield | base64_decode($row['user_sig_bbcode_bitfield']);
	// Cache various user specific data ... so we don't have to recompute
	// this each time the same user appears on this page
	if (!isset($user_cache[$poster_id]))
		if ($poster_id == ANONYMOUS)
			$user_cache[$poster_id] = array(
				'joined'		=> '',
				'posts'			=> '',
				'from'			=> '',
				'sig'					=> '',
				'sig_bbcode_uid'		=> '',
				'sig_bbcode_bitfield'	=> '',
				'online'			=> false,
				'avatar'			=> ($user->optionget('viewavatars')) ? get_user_avatar($row['user_avatar'], $row['user_avatar_type'], $row['user_avatar_width'], $row['user_avatar_height']) : '',
				'rank_title'		=> '',
				'rank_image'		=> '',
				'rank_image_src'	=> '',
				'sig'				=> '',
				'profile'			=> '',
				'pm'				=> '',
				'email'				=> '',
				'www'				=> '',
				'icq_status_img'	=> '',
				'icq'				=> '',
				'aim'				=> '',
				'msn'				=> '',
				'yim'				=> '',
				'jabber'			=> '',
				'search'			=> '',
				'age'				=> '',
				'warnings'			=> 0,
				'allow_pm'			=> 0,
			get_user_rank($row['user_rank'], false, $user_cache[$poster_id]['rank_title'], $user_cache[$poster_id]['rank_image'], $user_cache[$poster_id]['rank_image_src']);
		else
			$user_sig = '';
			// We add the signature to every posters entry because enable_sig is post dependant
			if ($row['user_sig'] && $config['allow_sig'] && $user->optionget('viewsigs'))
				$user_sig = $row['user_sig'];
			$id_cache[] = $poster_id;
				'joined'		=> $user->format_date($row['user_regdate']),
				'posts'			=> $row['user_posts'],
				'warnings'		=> (isset($row['user_warnings'])) ? $row['user_warnings'] : 0,
				'from'			=> (!empty($row['user_from'])) ? $row['user_from'] : '',
				'sig'					=> $user_sig,
				'sig_bbcode_uid'		=> (!empty($row['user_sig_bbcode_uid'])) ? $row['user_sig_bbcode_uid'] : '',
				'sig_bbcode_bitfield'	=> (!empty($row['user_sig_bbcode_bitfield'])) ? $row['user_sig_bbcode_bitfield'] : '',
				'viewonline'	=> $row['user_allow_viewonline'],
				'allow_pm'		=> $row['user_allow_pm'],
				'age'			=> '',
				'rank_title'		=> '',
				'rank_image'		=> '',
				'online'		=> false,
				'profile'		=> append_sid("{$phpbb_root_path}memberlist.$phpEx", "mode=viewprofile&amp;u=$poster_id"),
				'www'			=> $row['user_website'],
				'aim'			=> ($row['user_aim'] && $auth->acl_get('u_sendim')) ? append_sid("{$phpbb_root_path}memberlist.$phpEx", "mode=contact&amp;action=aim&amp;u=$poster_id") : '',
				'msn'			=> ($row['user_msnm'] && $auth->acl_get('u_sendim')) ? append_sid("{$phpbb_root_path}memberlist.$phpEx", "mode=contact&amp;action=msnm&amp;u=$poster_id") : '',
				'yim'			=> ($row['user_yim']) ? 'http://edit.yahoo.com/config/send_webmesg?.target=' . urlencode($row['user_yim']) . '&amp;.src=pg' : '',
				'jabber'		=> ($row['user_jabber'] && $auth->acl_get('u_sendim')) ? append_sid("{$phpbb_root_path}memberlist.$phpEx", "mode=contact&amp;action=jabber&amp;u=$poster_id") : '',
				'search'		=> ($auth->acl_get('u_search')) ? append_sid("{$phpbb_root_path}search.$phpEx", "author_id=$poster_id&amp;sr=posts") : '',
			get_user_rank($row['user_rank'], $row['user_posts'], $user_cache[$poster_id]['rank_title'], $user_cache[$poster_id]['rank_image'], $user_cache[$poster_id]['rank_image_src']);
			if (!empty($row['user_allow_viewemail']) || $auth->acl_get('a_email'))
				$user_cache[$poster_id]['email'] = ($config['board_email_form'] && $config['email_enable']) ? append_sid("{$phpbb_root_path}memberlist.$phpEx", "mode=email&amp;u=$poster_id") : (($config['board_hide_emails'] && !$auth->acl_get('a_email')) ? '' : 'mailto:' . $row['user_email']);
			else
				$user_cache[$poster_id]['email'] = '';
			if (!empty($row['user_icq']))
				$user_cache[$poster_id]['icq'] = 'http://www.icq.com/people/webmsg.php?to=' . $row['user_icq'];
				$user_cache[$poster_id]['icq_status_img'] = '<img src="http://web.icq.com/whitepages/online?icq=' . $row['user_icq'] . '&amp;img=5" width="18" height="18" alt="" />';
			else
				$user_cache[$poster_id]['icq_status_img'] = '';
				$user_cache[$poster_id]['icq'] = '';
			if ($config['allow_birthdays'] && !empty($row['user_birthday']))
				list($bday_day, $bday_month, $bday_year) = array_map('intval', explode('-', $row['user_birthday']));
				if ($bday_year)
					$diff = $now['mon'] - $bday_month;
					if ($diff == 0)
						$diff = ($now['mday'] - $bday_day < 0) ? 1 : 0;
					else
						$diff = ($diff < 0) ? 1 : 0;
					$user_cache[$poster_id]['age'] = (int) ($now['year'] - $bday_year - $diff);
// Load custom profile fields
if ($config['load_cpf_viewtopic'])
	include($phpbb_root_path . 'includes/functions_profile_fields.' . $phpEx);
	$cp = new custom_profile();
	// Grab all profile fields from users in id cache for later use - similar to the poster cache
	$profile_fields_cache = $cp->generate_profile_fields_template('grab', $id_cache);
// Generate online information for user
if ($config['load_onlinetrack'] && sizeof($id_cache))
	$sql = 'SELECT session_user_id, MAX(session_time) as online_time, MIN(session_viewonline) AS viewonline
		FROM ' . SESSIONS_TABLE . '
		WHERE ' . $db->sql_in_set('session_user_id', $id_cache) . '
		GROUP BY session_user_id';
	$update_time = $config['load_online_time'] * 60;
		$user_cache[$row['session_user_id']]['online'] = (time() - $update_time < $row['online_time'] && (($row['viewonline']) || $auth->acl_get('u_viewonline'))) ? true : false;
unset($id_cache);
// Pull attachment data
if (sizeof($attach_list))
	if ($auth->acl_get('u_download') && $auth->acl_get('f_download', $forum_id))
		$sql = 'SELECT *
			FROM ' . ATTACHMENTS_TABLE . '
			WHERE ' . $db->sql_in_set('post_msg_id', $attach_list) . '
				AND in_message = 0
			ORDER BY filetime DESC, post_msg_id ASC';
			$attachments[$row['post_msg_id']][] = $row;
		// No attachments exist, but post table thinks they do so go ahead and reset post_attach flags
		if (!sizeof($attachments))
			$sql = 'UPDATE ' . POSTS_TABLE . '
				SET post_attachment = 0
				WHERE ' . $db->sql_in_set('post_id', $attach_list);
			// We need to update the topic indicator too if the complete topic is now without an attachment
			if (sizeof($rowset) != $total_posts)
				// Not all posts are displayed so we query the db to find if there's any attachment for this topic
				$sql = 'SELECT a.post_msg_id as post_id
					FROM ' . ATTACHMENTS_TABLE . ' a, ' . POSTS_TABLE . " p
						AND p.topic_id = a.topic_id";
				if (!$row)
					$sql = 'UPDATE ' . TOPICS_TABLE . "
						SET topic_attachment = 0
			else
		else if ($has_attachments && !$topic_data['topic_attachment'])
			// Topic has approved attachments but its flag is wrong
				SET topic_attachment = 1
			$topic_data['topic_attachment'] = 1;
	else
		$display_notice = true;
// Instantiate BBCode if need be
if ($bbcode_bitfield !== '')
	$bbcode = new bbcode(base64_encode($bbcode_bitfield));
$i_total = sizeof($rowset) - 1;
$prev_post_id = '';
	'S_NUM_POSTS' => sizeof($post_list))
// Output the posts
$first_unread = $post_unread = false;
for ($i = 0, $end = sizeof($post_list); $i < $end; ++$i)
	// A non-existing rowset only happens if there was no user present for the entered poster_id
	// This could be a broken posts table.
	if (!isset($rowset[$post_list[$i]]))
		continue;
	$row =& $rowset[$post_list[$i]];
	$poster_id = $row['user_id'];
	// End signature parsing, only if needed
	if ($user_cache[$poster_id]['sig'] && $row['enable_sig'] && empty($user_cache[$poster_id]['sig_parsed']))
		$user_cache[$poster_id]['sig'] = censor_text($user_cache[$poster_id]['sig']);
		if ($user_cache[$poster_id]['sig_bbcode_bitfield'])
			$bbcode->bbcode_second_pass($user_cache[$poster_id]['sig'], $user_cache[$poster_id]['sig_bbcode_uid'], $user_cache[$poster_id]['sig_bbcode_bitfield']);
		$user_cache[$poster_id]['sig'] = bbcode_nl2br($user_cache[$poster_id]['sig']);
		$user_cache[$poster_id]['sig'] = smiley_text($user_cache[$poster_id]['sig']);
		$user_cache[$poster_id]['sig_parsed'] = true;
	// Parse the message and subject
	$message = censor_text($row['post_text']);
	// Second parse bbcode here
	if ($row['bbcode_bitfield'])
		$bbcode->bbcode_second_pass($message, $row['bbcode_uid'], $row['bbcode_bitfield']);
	$message = bbcode_nl2br($message);
	$message = smiley_text($message);
	if (!empty($attachments[$row['post_id']]))
		parse_attachments($forum_id, $message, $attachments[$row['post_id']], $update_count);
	// Replace naughty words such as farty pants
	$row['post_subject'] = censor_text($row['post_subject']);
	// Highlight active words (primarily for search)
	if ($highlight_match)
		$message = preg_replace('#(?!<.*)(?<!\w)(' . $highlight_match . ')(?!\w|[^<>]*(?:</s(?:cript|tyle))?>)#is', '<span class="posthilit">\1</span>', $message);
		$row['post_subject'] = preg_replace('#(?!<.*)(?<!\w)(' . $highlight_match . ')(?!\w|[^<>]*(?:</s(?:cript|tyle))?>)#is', '<span class="posthilit">\1</span>', $row['post_subject']);
	// Editing information
	if (($row['post_edit_count'] && $config['display_last_edited']) || $row['post_edit_reason'])
		// Get usernames for all following posts if not already stored
		if (!sizeof($post_edit_list) && ($row['post_edit_reason'] || ($row['post_edit_user'] && !isset($user_cache[$row['post_edit_user']]))))
			// Remove all post_ids already parsed (we do not have to check them)
			$post_storage_list = (!$store_reverse) ? array_slice($post_list, $i) : array_slice(array_reverse($post_list), $i);
			$sql = 'SELECT DISTINCT u.user_id, u.username, u.user_colour
				FROM ' . POSTS_TABLE . ' p, ' . USERS_TABLE . ' u
				WHERE ' . $db->sql_in_set('p.post_id', $post_storage_list) . '
					AND p.post_edit_count <> 0
					AND p.post_edit_user <> 0
					AND p.post_edit_user = u.user_id';
			$result2 = $db->sql_query($sql);
			while ($user_edit_row = $db->sql_fetchrow($result2))
				$post_edit_list[$user_edit_row['user_id']] = $user_edit_row;
			$db->sql_freeresult($result2);
			unset($post_storage_list);
		$l_edit_time_total = ($row['post_edit_count'] == 1) ? $user->lang['EDITED_TIME_TOTAL'] : $user->lang['EDITED_TIMES_TOTAL'];
		if ($row['post_edit_reason'])
			// User having edited the post also being the post author?
			if (!$row['post_edit_user'] || $row['post_edit_user'] == $poster_id)
				$display_username = get_username_string('full', $poster_id, $row['username'], $row['user_colour'], $row['post_username']);
			else
				$display_username = get_username_string('full', $row['post_edit_user'], $post_edit_list[$row['post_edit_user']]['username'], $post_edit_list[$row['post_edit_user']]['user_colour']);
			$l_edited_by = sprintf($l_edit_time_total, $display_username, $user->format_date($row['post_edit_time'], false, true), $row['post_edit_count']);
		else
			if ($row['post_edit_user'] && !isset($user_cache[$row['post_edit_user']]))
				$user_cache[$row['post_edit_user']] = $post_edit_list[$row['post_edit_user']];
			else
				$display_username = get_username_string('full', $row['post_edit_user'], $user_cache[$row['post_edit_user']]['username'], $user_cache[$row['post_edit_user']]['user_colour']);
	else
		$l_edited_by = '';
	// Bump information
	if ($topic_data['topic_bumped'] && $row['post_id'] == $topic_data['topic_last_post_id'] && isset($user_cache[$topic_data['topic_bumper']]) )
		// It is safe to grab the username from the user cache array, we are at the last
		// post and only the topic poster and last poster are allowed to bump.
		// Admins and mods are bound to the above rules too...
		$l_bumped_by = '<br /><br />' . sprintf($user->lang['BUMPED_BY'], $user_cache[$topic_data['topic_bumper']]['username'], $user->format_date($topic_data['topic_last_post_time']));
	else
		$l_bumped_by = '';
	$cp_row = array();
		$cp_row = (isset($profile_fields_cache[$poster_id])) ? $cp->generate_profile_fields_template('show', false, $profile_fields_cache[$poster_id]) : array();
	$post_unread = (isset($topic_tracking_info[$topic_id]) && $row['post_time'] > $topic_tracking_info[$topic_id]) ? true : false;
	$s_first_unread = false;
	if (!$first_unread && $post_unread)
		$s_first_unread = $first_unread = true;
	$postrow = array(
		'POST_AUTHOR_FULL'		=> get_username_string('full', $poster_id, $row['username'], $row['user_colour'], $row['post_username']),
		'POST_AUTHOR_COLOUR'	=> get_username_string('colour', $poster_id, $row['username'], $row['user_colour'], $row['post_username']),
		'POST_AUTHOR'			=> get_username_string('username', $poster_id, $row['username'], $row['user_colour'], $row['post_username']),
		'U_POST_AUTHOR'			=> get_username_string('profile', $poster_id, $row['username'], $row['user_colour'], $row['post_username']),
		'RANK_TITLE'		=> $user_cache[$poster_id]['rank_title'],
		'RANK_IMG'			=> $user_cache[$poster_id]['rank_image'],
		'RANK_IMG_SRC'		=> $user_cache[$poster_id]['rank_image_src'],
		'POSTER_JOINED'		=> $user_cache[$poster_id]['joined'],
		'POSTER_POSTS'		=> $user_cache[$poster_id]['posts'],
		'POSTER_FROM'		=> $user_cache[$poster_id]['from'],
		'POSTER_AVATAR'		=> $user_cache[$poster_id]['avatar'],
		'POSTER_WARNINGS'	=> $user_cache[$poster_id]['warnings'],
		'POSTER_AGE'		=> $user_cache[$poster_id]['age'],
		'POST_DATE'			=> $user->format_date($row['post_time']),
		'POST_SUBJECT'		=> $row['post_subject'],
		'MESSAGE'			=> $message,
		'SIGNATURE'			=> ($row['enable_sig']) ? $user_cache[$poster_id]['sig'] : '',
		'EDITED_MESSAGE'	=> $l_edited_by,
		'EDIT_REASON'		=> $row['post_edit_reason'],
		'BUMPED_MESSAGE'	=> $l_bumped_by,
		'MINI_POST_IMG'			=> ($post_unread) ? $user->img('icon_post_target_unread', 'NEW_POST') : $user->img('icon_post_target', 'POST'),
		'POST_ICON_IMG'			=> ($topic_data['enable_icons'] && !empty($row['icon_id'])) ? $icons[$row['icon_id']]['img'] : '',
		'POST_ICON_IMG_WIDTH'	=> ($topic_data['enable_icons'] && !empty($row['icon_id'])) ? $icons[$row['icon_id']]['width'] : '',
		'POST_ICON_IMG_HEIGHT'	=> ($topic_data['enable_icons'] && !empty($row['icon_id'])) ? $icons[$row['icon_id']]['height'] : '',
		'ICQ_STATUS_IMG'		=> $user_cache[$poster_id]['icq_status_img'],
		'ONLINE_IMG'			=> ($poster_id == ANONYMOUS || !$config['load_onlinetrack']) ? '' : (($user_cache[$poster_id]['online']) ? $user->img('icon_user_online', 'ONLINE') : $user->img('icon_user_offline', 'OFFLINE')),
		'S_ONLINE'				=> ($poster_id == ANONYMOUS || !$config['load_onlinetrack']) ? false : (($user_cache[$poster_id]['online']) ? true : false),
		'U_EDIT'			=> (!$user->data['is_registered']) ? '' : ((($user->data['user_id'] == $poster_id && $auth->acl_get('f_edit', $forum_id) && ($row['post_time'] > time() - ($config['edit_time'] * 60) || !$config['edit_time'])) || $auth->acl_get('m_edit', $forum_id)) ? append_sid("{$phpbb_root_path}posting.$phpEx", "mode=edit&amp;f=$forum_id&amp;p={$row['post_id']}") : ''),
                'U_RATE'			=> ($user->data['is_registered'] && $user->data['user_id'] != $poster_id),
                'U_QUOTE'			=> ($auth->acl_get('f_reply', $forum_id)) ? append_sid("{$phpbb_root_path}posting.$phpEx", "mode=quote&amp;f=$forum_id&amp;p={$row['post_id']}") : '',
		'U_INFO'			=> ($auth->acl_get('m_info', $forum_id)) ? append_sid("{$phpbb_root_path}mcp.$phpEx", "i=main&amp;mode=post_details&amp;f=$forum_id&amp;p=" . $row['post_id'], true, $user->session_id) : '',
		'U_DELETE'			=> (!$user->data['is_registered']) ? '' : ((($user->data['user_id'] == $poster_id && $auth->acl_get('f_delete', $forum_id) && $topic_data['topic_last_post_id'] == $row['post_id'] && !$row['post_edit_locked'] && ($row['post_time'] > time() - ($config['edit_time'] * 60) || !$config['edit_time'])) || $auth->acl_get('m_delete', $forum_id)) ? append_sid("{$phpbb_root_path}posting.$phpEx", "mode=delete&amp;f=$forum_id&amp;p={$row['post_id']}") : ''),
		'U_PROFILE'		=> $user_cache[$poster_id]['profile'],
		'U_SEARCH'		=> $user_cache[$poster_id]['search'],
		'U_PM'			=> ($poster_id != ANONYMOUS && $config['allow_privmsg'] && $auth->acl_get('u_sendpm') && ($user_cache[$poster_id]['allow_pm'] || $auth->acl_gets('a_', 'm_') || $auth->acl_getf_global('m_'))) ? append_sid("{$phpbb_root_path}ucp.$phpEx", 'i=pm&amp;mode=compose&amp;action=quotepost&amp;p=' . $row['post_id']) : '',
		'U_EMAIL'		=> $user_cache[$poster_id]['email'],
		'U_WWW'			=> $user_cache[$poster_id]['www'],
		'U_ICQ'			=> $user_cache[$poster_id]['icq'],
		'U_AIM'			=> $user_cache[$poster_id]['aim'],
		'U_MSN'			=> $user_cache[$poster_id]['msn'],
		'U_YIM'			=> $user_cache[$poster_id]['yim'],
		'U_JABBER'		=> $user_cache[$poster_id]['jabber'],
		'U_REPORT'			=> ($auth->acl_get('f_report', $forum_id)) ? append_sid("{$phpbb_root_path}report.$phpEx", 'f=' . $forum_id . '&amp;p=' . $row['post_id']) : '',
		'U_MCP_REPORT'		=> ($auth->acl_get('m_report', $forum_id)) ? append_sid("{$phpbb_root_path}mcp.$phpEx", 'i=reports&amp;mode=report_details&amp;f=' . $forum_id . '&amp;p=' . $row['post_id'], true, $user->session_id) : '',
		'U_MCP_APPROVE'		=> ($auth->acl_get('m_approve', $forum_id)) ? append_sid("{$phpbb_root_path}mcp.$phpEx", 'i=queue&amp;mode=approve_details&amp;f=' . $forum_id . '&amp;p=' . $row['post_id'], true, $user->session_id) : '',
		'U_MINI_POST'		=> append_sid("{$phpbb_root_path}viewtopic.$phpEx", 'p=' . $row['post_id']) . (($topic_data['topic_type'] == POST_GLOBAL) ? '&amp;f=' . $forum_id : '') . '#p' . $row['post_id'],
		'U_NEXT_POST_ID'	=> ($i < $i_total && isset($rowset[$post_list[$i + 1]])) ? $rowset[$post_list[$i + 1]]['post_id'] : '',
		'U_PREV_POST_ID'	=> $prev_post_id,
		'U_NOTES'			=> ($auth->acl_getf_global('m_')) ? append_sid("{$phpbb_root_path}mcp.$phpEx", 'i=notes&amp;mode=user_notes&amp;u=' . $poster_id, true, $user->session_id) : '',
		'U_WARN'			=> ($auth->acl_get('m_warn') && $poster_id != $user->data['user_id'] && $poster_id != ANONYMOUS) ? append_sid("{$phpbb_root_path}mcp.$phpEx", 'i=warn&amp;mode=warn_post&amp;f=' . $forum_id . '&amp;p=' . $row['post_id'], true, $user->session_id) : '',
		'POST_ID'			=> $row['post_id'],
                'SCORE'			=> $row['user_has_rated'],
		'POSTER_ID'			=> $poster_id,
		'S_HAS_ATTACHMENTS'	=> (!empty($attachments[$row['post_id']])) ? true : false,
		'S_POST_UNAPPROVED'	=> ($row['post_approved']) ? false : true,
		'S_POST_REPORTED'	=> ($row['post_reported'] && $auth->acl_get('m_report', $forum_id)) ? true : false,
		'S_DISPLAY_NOTICE'	=> $display_notice && $row['post_attachment'],
		'S_FRIEND'			=> ($row['friend']) ? true : false,
		'S_UNREAD_POST'		=> $post_unread,
		'S_FIRST_UNREAD'	=> $s_first_unread,
		'S_CUSTOM_FIELDS'	=> (isset($cp_row['row']) && sizeof($cp_row['row'])) ? true : false,
		'S_TOPIC_POSTER'	=> ($topic_data['topic_poster'] == $poster_id) ? true : false,
		'S_IGNORE_POST'		=> ($row['hide_post']) ? true : false,
		'L_IGNORE_POST'		=> ($row['hide_post']) ? sprintf($user->lang['POST_BY_FOE'], get_username_string('full', $poster_id, $row['username'], $row['user_colour'], $row['post_username']), '<a href="' . $viewtopic_url . "&amp;p={$row['post_id']}&amp;view=show#p{$row['post_id']}" . '">', '</a>') : '',
	if (isset($cp_row['row']) && sizeof($cp_row['row']))
		$postrow = array_merge($postrow, $cp_row['row']);
	// Dump vars into template
	$template->assign_block_vars('postrow', $postrow);
	if (!empty($cp_row['blockrow']))
		foreach ($cp_row['blockrow'] as $field_data)
			$template->assign_block_vars('postrow.custom_fields', $field_data);
	// Display not already displayed Attachments for this post, we already parsed them. ;)
		foreach ($attachments[$row['post_id']] as $attachment)
			$template->assign_block_vars('postrow.attachment', array(
				'DISPLAY_ATTACHMENT'	=> $attachment)
	$prev_post_id = $row['post_id'];
	unset($rowset[$post_list[$i]]);
	unset($attachments[$row['post_id']]);
unset($rowset, $user_cache);
// Update topic view and if necessary attachment view counters ... but only for humans and if this is the first 'page view'
if (isset($user->data['session_page']) && !$user->data['is_bot'] && strpos($user->data['session_page'], '&t=' . $topic_id) === false)
		SET topic_views = topic_views + 1, topic_last_view_time = ' . time() . "
	// Update the attachment download counts
	if (sizeof($update_count))
		$sql = 'UPDATE ' . ATTACHMENTS_TABLE . '
			SET download_count = download_count + 1
			WHERE ' . $db->sql_in_set('attach_id', array_unique($update_count));
// Only mark topic if it's currently unread. Also make sure we do not set topic tracking back if earlier pages are viewed.
if (isset($topic_tracking_info[$topic_id]) && $topic_data['topic_last_post_time'] > $topic_tracking_info[$topic_id] && $max_post_time > $topic_tracking_info[$topic_id])
	markread('topic', $forum_id, $topic_id, $max_post_time);
	// Update forum info
	$all_marked_read = update_forum_tracking_info($forum_id, $topic_data['forum_last_post_time'], (isset($topic_data['forum_mark_time'])) ? $topic_data['forum_mark_time'] : false, false);
else
	$all_marked_read = true;
// If there are absolutely no more unread posts in this forum and unread posts shown, we can savely show the #unread link
if ($all_marked_read)
	if ($post_unread)
			'U_VIEW_UNREAD_POST'	=> '#unread',
	else if (isset($topic_tracking_info[$topic_id]) && $topic_data['topic_last_post_time'] > $topic_tracking_info[$topic_id])
			'U_VIEW_UNREAD_POST'	=> append_sid("{$phpbb_root_path}viewtopic.$phpEx", "f=$forum_id&amp;t=$topic_id&amp;view=unread") . '#unread',
else if (!$all_marked_read)
	$last_page = ((floor($start / $config['posts_per_page']) + 1) == max(ceil($total_posts / $config['posts_per_page']), 1)) ? true : false;
	// What can happen is that we are at the last displayed page. If so, we also display the #unread link based in $post_unread
	if ($last_page && $post_unread)
	else if (!$last_page)
//added by ezermester:
$mytopic = new ForumTopic($topic_id);
$template->assign_vars(array('HIGHEST_RANKED_POST_ID' => $mytopic->getHighestRatedPost()->id));
//added by ezermester end
// We overwrite $_REQUEST['f'] if there is no forum specified
// to be able to display the correct online list.
// One downside is that the user currently viewing this topic/post is not taken into account.
if (empty($_REQUEST['f']))
	$_REQUEST['f'] = $forum_id;
// Output the page
page_header($user->lang['VIEW_TOPIC'] . ' - ' . $topic_data['topic_title']);
$template->set_filenames(array(
	'body' => ($view == 'print') ? 'viewtopic_print.html' : 'viewtopic_body.html')
make_jumpbox(append_sid("{$phpbb_root_path}viewforum.$phpEx"), $forum_id);
page_footer();
