Hi,
I’m having some issues with my 2015 Ford Focus. The dashboard lights flicker, power windows are inconsistent, and the battery warning light comes on sporadically. The fuses seem fine. Any ideas on what could be causing this?
hill climb racing
Thanks!
My 2015 Ford Focus is having some problems. The battery warning bitlife light intermittently illuminates, the power windows are unreliable, and the dashboard lights flicker.
Check the condition of the battery and its contacts. Maybe the battery needs to be replaced or the contacts need cleaning and tightening.
If the battery check light is on, it could indicate a problem with the alternator not charging the battery properly. Check the operation of the generator. You can do this at a service center or yourself, using a multimeter. Also check the alternator belt - it should be in good condition and properly tensioned.
Make sure the battery terminals are securely attached and not corroded.
